Standard BOV venting
pl0x
v5/6 ones are pretty shit at venting to atmo. unless you have a link you will have idle issues and stalling when you come off boost. This is because the factory valve is too soft an does not close fast enough nor FULLY close under high vacume (after boost ect). welcome to try its only one hose clamp then bung the intake pipe side with a 32mm bung from memory.
Sweet thanks for that dude. thats what i had heard but just checking
I don't have the plumb back pipe anymore haha. If i use it, its going to be a temp measure to keep the car driving until i fit front mount & new bov
Also i have a link but its tuned to run my gfb one so most likely to still have the stalling issues?
nah if you hav a link it wont stall at all but will vent real easy and comtimes you can hear the valve leaking air on partial throttle. will still work fine at venting boost and sealing under accel but yeah not ideal and sound real gay too :-\ lol. And yes it is cus of the afm as its usualy ither metering too much air or not enough air depending on what your valves deciding to do lol. But since you have a link the map will be all good, doent matter what valve it was tuned for as its not really caring what the valves doing if that makes sense to ya. (ovcource partial open on throttle may effect your tune a TINY bit but basicly NOTHING. ;D
