Power FC Question
JWDRPN
any experts on power fcs around here
my car has been sitting dorment for a good few months mechanic went to start it it wouldnt turn over it was cranking but wouldnt start
hand display was working but the car wouldnt crank
he put a ver3 ecu in and BAM car started
nothing on the ecu has been touched just motor out motor in nothing else has changed!!
any ideas
i read on this
http://paulr33.skylinesaustralia.com/docs/powerfc-faq/powerfc-faq.htm
but this has already been going to the point i drove in to the mechanic it has a tune
i dunno i need help
Guest loren
any errors on the hand controller, or sensors reading illegal values?
do have the boost control option turned on without having the apexi boost controller attached?
any errors indicating on the dash?
is the tune on the power FC so bad it just won't run at all? have you tried to reset it to the factory tune?
the hand controller is powering on as per normal
the boost controll option is always switched off havnt used it...but its worth checking again may also pay to check the afm while im at it
no errors on the dash
i havnt reset it to the factory tune that would be the worst case sinerio!! and at this stage until im absolutly positive that every other way has been tried then i will do that
