Strange electrical problem
Got an issue with our 250T, it happens quite often that the dash lights and headlights will pulse, they get dim and bright, dim and bright, it also idles roughly when this is happening and occasionally stalls at intersections when its cold...
I've tried cleaning the airflow sensor, but it does sound like a servo motor or something similar is trying to work when it does it but I don't think its the idle air control, its coming from the drivers side front of motor... maybe its just noise from the belts as the idle changes... hmmm... also the ABS light sometimes comes on for no apparent reason... any ideas?
also check your crankshaft pulley is not loose !!!!!!! seen this a couple of times where people dont torque the pulley bolt after cambelt work ect, can **** your crank and pulley woodriff key ;)
  • 3 months later...
