Cutting out at 0.8 bar
I've just picked up a 1995 WRX. It's got a full 3" exhaust and a pod filter. Not sure what make the pod filter is but it's a cylindrical one with a hole in the middle.
The car is boosting up to 0.8 bar and then it cuts out, comes back, cuts out, comes back, cuts out, comes back etc. If I ease through the acceleration it doesn't cut out and it goes right through the rev range so all I can think of is that the computer is causing the cut out.
I did these same mods to a 1993 WRX that I had last year and it boosted to 1 bar before cutting out.
There is a slight exhaust leak by the turbo that I have to fix. Could this be the cause of the problem?
Could anything else be the cause of the problem?
It definitely feels like the fuel cutting out. I can go through the entire rev range smoothly as long as I keep the boost under 0.8 bar.
I have a boost tap so I can check it with that. I just can't remember how to install it properly. Can anyone help me with that?
