Brake Upgrade For BF GT?
I have a 91 BF Legacy GT an have access to the next generation legacy brakes are these bigger in rotor diameter/thickness/caliper can any one tell me? also will they bolt up?
I only ask as the later model Legacy parts are free. Have done similar upgrades on GT Corollas as there brakes bolt up.
Any info would be great thanks....
What model Legacy brakes do you have available? The 2 pots from the GTB/RSB run a slightly bigger setup. However it also means you cant fit factory BF rims over them.
Personally I would suggest decent pads and fluid is all you need to do to the factory brakes unless your running slicks.
