97 type r dccd light flashing
Help needed... does anyone know what to look for my dccd light is flashing and i cant seem to reset it... anyone had this before or know possible causes ???
no not yet... a while ago it did this and was suggested to pull hanbrake on rock in reverse on clutch then do handbrake stop going forward ... and this seemed to fix it.... Then our lovely mutt jumped between seats two days ago and rolled controller right forward to full lock while driving and now its just flashin green
 BIGKNUTS']
in saying all this about dccd ... my dccd has started flashing on lowest setting ... does anyone know possible causes HELP ???
[quote name='kamineko said:
diff coil failure usually :( or check the wiring to the diff
in which case there is a guy selling his dccd transfer case for $250 or something in the FS threads, pretty good deal
before buying that get yours checked properly first. the coil will have an impedance and you can measure the resistive component with a multimeter. i can find out the proper value for you today if you want
can you stick to one thread please? i just deleted your other two, and i will keep deleting any more you create about this!
grrrr grumpy kamineko is grumpy this morning :P
