1991 Legacy BC7 Oil Leak
soobie spinner
Hi guys. I have a 91 legacy 2.2L non turbo which has an oil leak on the left side of the engine(if you're looking at the engine from the bumper). Im pretty sure its coming out of the tappet cover gasket cause thats where i can see the drip. I just wanted to know how hard it is to change the gasket over and what do I need to do to change it. And do I have to drain the oil or just wait for a while for it to go back into the sump?
Thanks alot guys!
As always bery much appreciated. ;D
it has been covered endlessly on here have a wee search to find what u seek (it may even be a sticky or should be)
easy as job
remove airbox for driver side and battery/washer resevoir for passenger side,remove nuts from the engine mounts (2) jack up engine,remove coils if they are in road,undo all bolts,remove tappet cover,replace the gasket WITH GENUINE one only,replace the bolt washers,reinstall all
