B4 true dual exhaust...would it work?
My name is Rob and I posted on this site some time ago. I'm building a Purvis Eureka kit car (based on a 1969 VW Beetle chassis) and using the motor from a 1999 GTB (bh5 rev b) to power it. The engine is mounted at the rear of the car (this is important in terms of orientation later on). Project has come along nicely, but I have to start thinking about exhausts. I want to have two mufflers at the rear but I'm fairly limitied on space. So my thoughts are:
1) i'd run 2.5" down pipe from the primary into a cat then wrap under the engine and straight out through a muffler
2) then I'd run a separate 2.5" (possibly 3") down pipe from the secondary into a cat then wrap under the engine and straight out through a muffler
Thoughts? Overspool? Balance pipe between the two systems? Would it sound funny with all the exhaust through one muffler and then both during the secondary stage?
Cheers,
Whereabouts are you locating the turbo's? i.e. where they sit in a Subaru so would now be in front of the motor?
Still using the factory manifold? Cause that would take care of your balance pipe. Not sure what size is recommended for the TT's though sorry. Two 2.5" pipes sound large though. Someone should know what the TT aftermarket downpipes normally use diameter wise.
