Clearances from exhaust pipes to steering colum and its universals?
Guest vf20/21bg5
Guest vf20/21bg5
Havnt got time to look it up,buisy buisy buisy ;) so does anyone know? my up pipe is pretty close to the steering collums universals! Thanx to my big bulky plenum ive had to mount the turbo lower dwn then id liked
the pipes on my clevo in my legacy are pretty close, so close the right hand manifold faces forward, and the exhaust runs around the front of the motor, wouldnt have 10mm more like 5, doesnt seem to cause any issues
Guest vf20/21bg5
 zarnah said:
mine clears the steering universal by about 10mm :)
ok so no issues with cert or wof? mines about 15mm clearance......the reason i asked is that i thought the heat from the up-pipe even tho its wraped would dry out the grease in the steering collums universals causing them possibly to seize......well hope i dont get caught up on it as it is where it is now! To change it would be a mission! ;)
