Strange problem (96 GTB)
B_Man
So last night I was driving home from work, Gave it some curry in 2nd gear up to the speed limit, there was a bit of hesitation during the second turbo boost,
Now as I was getting off the motor way, the CEL, Steering light, and catalytic light came on, engine power DIED, then kicked back into life again.
Got to wifes work, checked for codes and no new codes where present.
I have had code 22 the time I have owned it, which comes up every now and then.
Any ideas?
Guest S T  E Y E
yeap normally alternator will make all the lights come on...check and clean the conections and also check clean the battery terminals too as this can do it..
use a multimeter on the battery and test for alternator charging
