could this be electrical, how could you tell
mate could really do with your advice again,
ive had diagnositics done, nothting showed up, had carb cleaned etc and new fuel filter
now lets remember this only happens when engine is cold,
note i parked in garage this week, had no problems in morning even though still cold, today was the real issue
was parked out stide 5am-3pm , had small frost first thing, no rain, just sun, got quite hot,
drove 2 min from carpark down road, and yes again problem happens, was doing about 20 - 30 kmph, accelerating at the time,
next thing i know car almost stalls, drops from 30 kmph down to bout 2 kmphj, engine tring to stall, car stops in middle of road, not bunny hopping as its auto but the equivilient,pull over, try to push on the gas, nothign happens no revs no acceleration.car is shuddering and really clunky and noisy, sounds like no oil as really really loud, sounds like wanna blow up, happens for aobut 30 secs, then stalled(not to mention first time it had stalled) , tried to start straight after but turned over for about a min without starting, tried again and started again, drove 20 meters , had slight drop like wanted to stall again then came right.
so this only happens when engine is cold,
note it only happens sometimes
this morning was worst it has ever happened and didnt sound of feel good.
still no codes showing up
have had diagnostics, still nothing.
have put in carb cleaner and also motor up fuel system cleander and engine treatment
have also replaced 2 afms just in case but positive its not this.
tomorrow i will get a original air box and another afm to try, but really dont thoink its this.
some mechancs have said coils, some have said fuel injectors
really need some adviceo n what to do next or were to go, can anyone help me that can actually help .i dont have much money and can do this work by myself, need someone that konws were to look and how to pull apart and put back together a engine, please your help would be appreciated, like i said no mechanic i have seen , has been able to help yet!!!!!!!!!!!!!!!
hmmmmm. ahhhh hard to tell but does it feel like its cutting ignition or fuel??? next step id be doin is trying a new computer dude.... probly not the problem but i have seen them do verry funny things....
Hey mate - see my post in the message you posted in the 'Motors & Turbo' section.
thats the name of the stuff you use to clean the throttle body... its carb cleaner. good stuff in enclosed spaces...
