ENGINE BUILDS - from STD to MILD to WILD
send me a PM if you need a rebuild
Engines built to your needs and budget
Note, will not build any engines for retards, or anyone want to do 1/2 a job
QUALITY ONLY
Guest vf20/21bg5
Hey cheers for those v5 sti cams you got me for my build, got them read and were mint! :D will be perfect for my build, Franklin cam services said i wouldnt need a cam grind for my setup so that saved me $$
How much would I be looking at for something that's got a fair bit of power, Mainly used for long road trips but still has grunt when it's needed.
Not after something for track use, But still something built to last.
Along with a manual conversion to boot lol
Actually to add to that, Would almost consider rebuilding mine, It's got 230k on it but I've test drove a fair few legacy and still haven't found one that runs as nicely as mine. - Stock might I add so people don't go having a whinge.
Hi Ichi Ban, looking for someone to do up a closed deck block,(which I have but has run b.e. after start up) I have vf46 to go onto it plus pink injectors, looking at getting GTB head also, looking at getting around 300kw if possible. Would you be interested , what would be the cost to build ? Cheers
300Kw atw?
What crank ,rods, pistons, exhaust etc you thinking of running?
You'll need to some serious work on the heads, ie porting and cams
PM me if your serious and we can go from there
Cheers Rick
 smokn4 said:
also interested in a std build...just something to get from a to b sort of thing.....
can you pm me a cost to do this.....
chur
What do you have to start with ? a blown engine or wanting to build from scratch ?
A basic SOLID rebuild to handle 250Kw is around the $8k mark, fully forged, balanced, Stud kitted
What's wrong with you engine?
Does it just need a TWEEK?
Have my 05 Blitzen for sale if your keen for an upgrade
PM me if ya keen
hey ude i have a closeddeck block the has been honed but proberbly needs to be done again.and i have a 2.2l crank and rods. would love to see 500hp at the wheels..its still in the pipeline..but do you have any ideas mate as i have no idea what to do for pistons etc...
