Auto Gearbox problem
driftweez
Ok this is my problem hope someone can help me out. Have a 94 Legacy TT Auto. It drives fine till it has to change up from 3rd to 4th gear(overdrive). A lot of the time especially if it has been floored or has been holding 3rd up a hill it will stick in 3rd for a minute or even longer sometimes shorter without changing up. I can physically feel a looseness in the accelerator pedal and then when it does eventually change to 4th I can feel the pedal move out about 5mm and tighten up as per normal. I have no real idea. Trans fluid flushed still I have this problem. Has been like this for a couple of years and no one can work it out..Cheers
Hmm, that pedal feeling thing is strange, and I suspect not the cause or even a result of the gear change.
The first thing you need to do is get the trouble codes. Which I suppose has been done before?
Second, if there are no trouble codes, you need to have the hydraulic pressures checked if you want a good diagnosis.
Let us know if there are any codes first.
