98 Legacy conversion: Auto to Manual...
I noted an earlier thread on this subject, but I have a few more questions.
I believe I have almost everything needed: manual gearbox, gear lever, prop shaft, rear diff if necessary, pedal box, hydraulics, clutch plate, cover & flywheel.
What I don't have is the center console (cosmetics... not bothered) the gauges (do I need???) and an ECU for a manual (do I need???)
In the previous thread there was the comment "and a bit of wire to cheat the system for the big grey gearbox plug". Doesn't this imply the auto ECU can still be used???
Any comments would be much appreciated, but I have the impression this will not be too hard to do.
Thanks in advance...
--paul
Guest vf20/21bg5
Ive done it on a 96 gt and yeah its a wee bit of a mission ay, just when you think you have everything you usually dont lol.....there is alot of info on here way back bout the conversion enjoy tracking it down but they are basicly the same as converting impreza's too ive been told. And no manual ecu, i just had to get a manual dash cluster and have the speedo wired in
