best way to remove gutter strip?
dubbedup
start at the windscreen end, lift the inside edge of the moulding away from the glass, you may break the little white clips but once you see one you'll figure out the best way to unclip them. Once you've unclipped the bit that goes down the windscreen, slide the whole thing forward, the big grey clips will stay attached to the moulding and unclip from the roof rail studs
thanks stoffa,
i have got it off, but the replacement one also has clips broken, im thinking about the using some windscreen sealant to hold it in and gclamps to set it, can anyone see any issues with this...?
haha hori i know
