v5/6 to v7 compatibility
raymong
yes they'll bolt up, but the V7 throttle body, injector rails/injectors and sensors wont are different from v5/6. Which isn't a problem if your using a link, but if your using a v5/6 ecu it'll be a huge drama to make it work.
That'll work as long as you change the toothed crank pulleys over (the pulley that has the little tabs that the crank sensor reads) your version 7 one has 20+ tabs where the V5/6 ones only have about 10 from memory. They use different crank/cam sensors between the models and you cant mix and match them
Here's a V7 one
