Sti 4 pots calipers and non-abs wrx
yeah you could and your discs of course... but your backing plat behind the disc may be smaller so change that too.
if your goin to do that i would just swap over the easy stuff as cvs can be a right c u n t if you cant hit them off easy they usually dont play nicely
Your wrx not have ABS? Will your rotors and callipers still work on my leggy and my ABS still work?? I have a 32mm socket too if you need
its a v1 so id say it wouldnt have abs.... still think you should just change caliper and disc.
I'm buying dubbed up's old rotor's and callipers off him to fit to my NA leggy with ABS. will they fit on my hubs and my ABS still work ok?
yeah the caliper and rotor has nothing to do with abs... the sensor is in your hub and the abs ring is on the cv joint. it will be fine...
