VF23 vs TDO5
 WRXONP said:
My vf23 doesn't taper power off at top end . .. Pretty sure the exhaust has allot to do with it also air intake . . . . Im pretty sure ill get 210 + on standard ecu :P
ive been more dyno day then you ever changed your undies... ive seen STI getting 180-220 depending on supporting mods... how fresh is engine, tired turbo? new? heads, cams, extractors, exhuste ect... ive seen people spending lots of money on their car and still get 190kw, just remember... is power over cost.. what it cost you to get an extra 5kw?? $1000?
if you really want serious power get meth/water injections, nos, do your cams... cams is always under looked
if you really want to have a good dyno plot just ask the tuner to ramp it or just photoshop... at the end of the day your dicck still small ( im not pointing at anyone )... power dont mean s***t until u show some time on the track or down the strips
if you want to impress anyone post up your times and track under your signiture
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
This is suspose to be a vf23 compressor map.
Anyways you can see it flows its best / makes its best power at arround 1bar and is struggling once we get to 1.4bar.
Which is one of the reasons why on a good flowing engine high manifold pressures can not be held at high rpms
