HELP!!!!
failzorz on the leprocy wagon!
ok really strange gremlins have taken over and decided that when the car is stationary that the power steering is NON EXISTANT!! however! when driving they have given it back to me!??
when car is stationary, the steering is heavy and the lights come on on the dash when moving the wheel
+ there IS the required amount of power steering fluid in the reservoir.
this maybe related to this : http://www.clubsub.org.nz/forum/index.php/topic,23691.0.html
and follow up to that other thread , the A/C has been disabled ( belt gone ). and alternator belt spins fine and is at usual tension. ( iv had an alternator die on me before and this is different )
 dacerx said:
Your car wants to be manual steer that's what it's telling you
but only in stationary position? you can see how this would be an issue sometimes?
im really concerned that it could be a warning of sorts that something is about to fail / has failed ?
 ADIKT said:
Power steering belt slipping? bung power steering pump?
the power steering belt is the same belt that is on the alternator as well.
does not explain why the steering is perfect while driving. this is only when stationary.
just an idea but could it be low voltage to the pump due to less volts being returned to battery from alternator while stationary? i would imagine that when driving the alternator would work more efficiently and supply a higher voltage? or am i barking up the wrong tree?
 ADIKT said:
What would it have to do with the alternator? I would try a new power steering pump first of all..
dam bet me to it I have a spare one if u want to try another one and also out don't have sports steerring on all the time? But yeah come over get it and change it over
sports steering is not hooked up for some reason? the switch on the dash is non fuctional and has been that way since i got the car, is that a bad thing? why would it not be working?
ok so im pretty sure its the pump.
reason being. i popped the bonnet and turned on the car. turned the wheel and the pulley for the power steering stopped spinning!!
do you guys agree that its the pump and i should replace it?
does anyone have a good one for sale? ill give you $50 for it.
 dacerx']
Go try this one first... and if it works make him an offer ? ??? and if he doesnt wanna sell it to you then you know for sure what you need to get :)
fixed! was the power steering pump. have replaced and put in new fluid and she is mint again!
piss off gremlins haha ( im sure you will be back soon ! )
