WRX Central locking issue
put an alarm in a '02 ish WX recently and all went well apart from the central locking. had originally hooked it up to the single white control wire down by the drivers footwell but for some reason (i dont exactly remember why) it wasn't working then eventually found it had negative triggers going into a big control unit under the steering wheel, so hooked it up to them and away it went. now the guys rung me up saying that every now and then the drivers door wil lock unlock lock unlock lock unlock really quickly for no reason. also, the manual central locking (physically lock drivers door then other doors lock aswell) has stopped working and i can't find why. all fuses are ok, white wire has been reconnected. now if i pull out the central locking fuse under the bonnet, this completely solves all problems...but it is also the main fuse for the dome light and the clock. any ideas why the central locking is doing this?
nah i've never had that problem before and i've fitted two alarms with negative door triggers to same year vehicles. maybe a faulty central locking box? or if u used the wires directly from the plug coming from box - a back voltage feed back into alarm? since i only fit alarms with negative triggers i generally pull apart the relay box and use a test light to ground the actual pins on the board which activate the lock/unlock relay and solder wires to it
i tried that single white wire method too - while it worked in my mates car with a mongoose alarm already fitted to car... it failed to work with my alarms - hence i attacked the box! i had the repeat lock-unlock happen as well with the white wire...
my mates ones been in the most part of the last year and no problems yet
