Broken IACV
Hailz
Howdy all, last nite the old Rs started playing up and doing funny things and has spat out a code 24 (idle air control valve) makes sense seeing as it was revving all over the show, my question is what's the usual fix for these? Can they be repaired or should I replace it with a second hand one? And can you get the gaskets from ripco and the likes?
 Bazza-NZ said:
Mine broke a while ago so i just removed the whole unit and took it apart. Cleaned it all out and put it back on. Been working mint ever since so you could try that
Sweet I'll give that a go then, were you able to get a gasket from anywhere for it or did you just make one?
Cheers!
 Hailz']
Cheers!
Went to Subaru to get one, X-Japan and would have been 12+ days so, but a mate had a spare new one for some reason so i used that. I don't see why you couldn't reuse it with some goo? Arn't they metal?
