02 legacy hard starting sometimes when cold
Hey Guys, Why would my legacy sometimes take longer to turn over when cold then when hot. Only does it sometimes.... Usually cranks over no worries but then every so often it will take a few more seconds.... Battery and starter seems sweet!
Well it seems to prime ok do I just let it prime for a second or two before starting each.time or is it a sign pump on way out. Maybe time for a walbro
Also the water temp sensor how.does that work? Say if its not working properly it wont tell the ecu that the car is cold so it wont put extra fuel in? Anyway to check it since it's not a problem all the time or do I just buy one and give it a go?
yup coolant temp sensor if its bung can think its warm etc and not tell ecu right stuff
reckoned that happened to my ol' 90 GT (Auto) that would actually stall when cold!
I traded that in before I found out what the actual problem was
