Ecu loom swap.
94 Leone
Okay, as some of you may know, I'm converting my BH5 to N/A I have the engine and ecu, but no loom...
However I have a wrecked BG3 I took the ecu from it to see if it was 3 plug like the ecu for the new engine... It's only a two plug, but the two plugs it does have match up with two of the plugs on the Engine's ecu.
BG3
BG3 ECU is:
Make:Hitachi
Model:V1
Top line code: |2261 AB520|
Second line code: MECF-E10 B1 4906
EDIT:just noticed a number on the side it is:
MECF-E10 B1 04558
new ECU
New ECU is:
Make: Unisia Jecs
Model: T9
Top line model code:22611 AB360
Second line code: A18-000 RV3 4607
The plan is to swap the loom into the BH5 along with the different ecu.
I was wondering what does the middle plug of the T9 ECU control
(to find a level of importance) and would the V1's loom work properly with the T9 ECU
If not, does anyone have an engine loom that would fit the T9.
Cheers.
Harley.
