250T Shudder only when turning left??
GT_Head
I have a 1996 BGC 250T auto and after replacing both outer CV joints I have a vibration in the front under load turning left only. I have driven a car that has knackered duty solenoids and am confident it is not that and I have put the fwd fuse in to check this also. I have swapped the half shafts left to right, replacing the half shafts with other units (both sides and one at a time) all to no avail. At first it felt like a hub nut was loose but all nuts and bolts were checked and we have checked again trying to eliminate the problem. Have checked diff fluid and trans fluid both are at level and clean .... Any suggestions would be greatly appreciated or a new direction to go down. Thanks in advance ......
