engine check light on after rebuilding starter motor
tez n u
hey guys my cars engine check light is on and is not goin away :( car drives normal and if i turn car off and leave it on just ignition the lights flashes......5 long flashes and 5 short flashes, anyone know whats going on here?? I run a plug in link g4
 Stoffa said:
sound like you'd need to ask whoever tuned it, or possibly call link themselves, they're very helpful on the phone
you may be able to figure it out yourself with a laptop and the link software
Yea while hooking up the starter i short the positive wire by mistake if that makes any difference
Yup without air temp sensor, just fixed it with pappu's help ;D. i downloaded the pc link software and cleared the fault codes stored on the ecu and now its gone ;D .......so we cant turn on the car without the air temp sensor (if one is fitted and used) without the engine check light coming on.
Correct, even if you re-connect the sensor after you have turned the car on without it it wont forget and needs the code cleared with the laptop and pc link. Didnt see this post earlier lol
