2001 tt gtb etune vf13secondary turbo (drivers side)
anyone know what this turbo is doing on the drivers side..always thought vf13 was a primary and vf14 was secondary, i'm the first nz owner plus isnt it ment to be vf27 as the secondary ???
pretty sure 2001 gtb are ment to have vf27secondary but could be wrong i carnt work out why a vf13 is on the drivers side isnt a vf13 on the passangers side.
2001 is a change over year.. Revision C or D? Factory set up for Rev C is VF31/VF32 and Rev D changed the primary from a VF31 to a VF33 giving it a VF33/VF32 combo. It wont have a VF13 on the secondary side unless someone has created a hybrid turbo using a different exhaust housing.
tried to fit a vf14 but wouldn't fit and now i dont want to waste money on another turbo to find out it wont fit....saw a vf27 on tm now i stuck on what i should do ???
yea was bummed on the vf14 not fitting and can only think it is because its off a early model and am def hoping that the vf27 or the newer one will fit, if anyone knows if the vf14 should or shouldnt fit could you let me know :)
all i knows is that the secondary (drivers side) turbo that got taken off my sub was a vf13 dammm im stumped! im the first nz owner of the car and have not modded it at all
