Changing gearboot on 2001 Legacy
Hi all!
Has anyone replaced the gear lever boot on their Legacy? It seemed pretty well secured last time I had the console apart and I want to fit my replacement one (generic... not a factory fit one) tonight.
Thanks!
Yes.
Its easy but you have to take care and be prepared.
a) remove the surround from its home
b) there are small metal circles on small thin frail plastic stalks...
be nice to them and take them off slowly (You will thank yourself if you remove them without destroying things)
c) remove plastic frame holding gearboot on and remove boot (it is glued on so be carefull)
d) clean old residue off
e) install new one - here you can either glue or not
f) do above in reverse
PS I did this 4 years ago so may have missed some detail - just take your time and be patient
