2.0 to 2.5 swap
Disruptz
Ehh, Iv'e blown my piston ring, and the car is a bit shite..
So now it's the perfect excuse to upgrade while the engine gets pulled.
Has anyone done the 2.5 swap for the v7 MY01 (bugeye)? Is this possible?
There are a few 2.5's from the forrester XT's, I wan't to swap it in my v7. Will this be a direct fit?
need some options,.. I'm gonna add a td05-18g/16g and larger injectors +Link ecu. (Looking for easy mid-high 12's)
Or should I stick with the 2.0?.. downside be I have a auto. So with the 2.5 that should combat the turtle like movement off the line. :)
My mate kinda did that on his V4. Id say itd be the same deal on a v7. His was more sorta built up though. I remember when he just put it in, it went absolutely loose. What exactly did you want to know?
i researched this when my motor blew..
basicly if you want to make power more than 220kw you got to spend ALOT of money on building a motor and heads etc......
The normal sti heads arnt that great to match to the 2.5 (my understanding)
in saying htat it can be done and it is possible and it will most likely be more torquey but if you want any decent power be prepared to spend lots
SUBOUT on here is buildoing one at the momenet and has spent alot i belive......
yes it would bolt in fine yes..
and if you wanted to just have a standard 2.5 with a link then it would work fine..
problems begin when you want more power as takes a lot of work to do something decent..
PM subout he knows a fair bit about them as hes building one as we speak
