LED lights in bonnet vent
Guest Eastwolf
Guest Eastwolf
Hey guys.
I have a crazy idea to get a LED strip (similar to those seen on Audi headlights) and mount inside the bonnet vent.... I am not techno minded so would like some hinters please.
Issues;
1) how can you control it? on/off from inside cabin?
2) where will you power it from? It ain't as easy as plug'n'play USB?
3) will it cause over-heating issues? the vent is made for air, so probably not good to block it.
Appreciate your thoughts.
hey there,
may help to have a look at this, guy asked Q's bout the legal side of a neon(light sorce) in there in this i think
http://www.clubsub.org.nz/forum/index.php?topic=1566.0
wireing, easy, switch in cabin, feed from ACC, with a fuse. probly not plug and play.
over heating... not sure, spose its not designed to have any obstical in the area. but im sure people do it.
-smurff
 Glen said:
I did this. Wired them to the alarm LED so they only went when the car wasn't running.
well i like that idea, that could be fun
-smurff
 smurff']
-smurff
All legal too. Despite what the first WOF tester thought until he went and asked someone else.
Guest Eastwolf
I seen better ones on e-bay...
thinking that I will change from simple white LED to knight rider.
Just not sure how to connect?
ideally it would scroll/scanne red a few times when u arm/disarm the alarm... but the eletrics wil just pulse the park lights..... therefore you'd get half a scan x2 when disarming... hmmmm.
maybe I could connect to the dome light so that it scrolls when the doors are open?
idea? comments please?
Hey this isn't really constructive but when you figure it out could you please PM me on how you did it? I have been thinking about putting a green l.e.d in just behind the grill of my Legacy for a while now. Was thinking of even making it strobe when car was parked up? And as far as I know its legal if you can't see the light source and they don't strobe or change colour while driving. What I will do if i do mine and can afford it (and have a sick as sound system) is get green under car ones and run a bonnet vent one aswell (God I'm gonna need a new hood when I get a new engine for a top mount). If not, why not just attack some under car kit and use the wiring from that for it or something?
You will be able to get a timer that is switched on by the park lights or whatver flashes when you arm/disarm the alrm and then continues to supply power to your scanner thing for however long you want. Search Jaycars site.
Guest Eastwolf
If you want it to strobe when parked you can connect to the ignition.. I had a friend who installed a deterent type flashing diode that came on when ignition was off on an old car.
As for legal. I understand that you cannot have any naked bulbs visible (or changing colours for that matter). The ambient glow is fine.
Peace out
Are undercar neons legal whilst driving then? Just an ambient glow? And will I get pulled up when I put lights in my boot under the plexi floor (to be installed soon)? Because I imagine those will light the boot up like a christmas tree.
As for under the hood, for strobing I could hook it up to the light in the roof maybe? For like when the internal lights are on?
Guest Eastwolf
Thanks for the link. had a look.. so basically it's like a UPS for a computer? Keeps power flow for a certain period?
Do you know how much?
