Random error codes
crazy-jono
So I started my car this morning and it was idling to high and then hunting up an down as if the airflow meter was stuffed.
i took the car to autotech in Christchurch to get the fault codes checked and they came up with 63 and 29 which were not in there system.
so another fun surging an cutting out drive to Rick Armstrong and got it plugged in there and still got faults 63 and 29.
fault 63 - Relief Valve Control Solenoid
and
29 - Cam pos no 2.
the guy said he hadnt seen those faults before and is going to give me a call later when he fines out more info.
Has anyone had a similar problem?? ??? ???
it a 1996 v3 sti impreza with standard everything but k&n pod filter and vf24 turbo.
yea they cleared the codes and took it for a drive before going to Rick Armstrong.
he plugged the box thingy in a checked everything again and still same codes
Well the recommenced procedure is to start checking those two components as per the manual, but...
years of experiance tell me that those two things both starting together probably means they have something in common, and I don't think it is going to be electrical.
Because it's simple, and cheap, and could cause both codes, I'd check your cam timing first. Just pull the cam covers off and check that the marks line up.
If that's ok, check for bad earths and do the component tests as per the manual.
yea the lines match up perfect.
the car has been boost spiking to 25 psi when in cold weather for bout 6 months but codes only popped up today after it started surging and cutting out.
got new clamps on battery last month
so it could be air flow meter and relief valve?
Scope the cam sensor output at the ecu pin, and scope the battery voltage
Have seen interference from the battery!! caused by alternator recifier failure (esp if you usung gell cell type) transfering into the cam sensor line
Had cam and tps logging on a car earlier this year ( was due to the aletrnator and fitted std lead acid battery all good !!
Yes this took some hours to find !!
