Hey guys, today my cars ABS light just popped up and now wont go away. I tried a few brake tests and ABS is not working. Any ideas on what it could be.
its a 2000 Sub Legacy B4 RSK
Thanks in advance
ABS diagnostic check will tell what is causing the warning light
ive got a mechanical and electrical warrenty but wanna see if i can fix it before i claim on it as there is a 250$ excess
Diag check at dealer is easiest (prob charge you bout $50) THE BURGLARS !!!
Then you can decide to put in a claim or not depending on fault
its weird sometimes it comes on sometimes it doesnt. Might get soem contact cleaner and clean the ABS plugs
typical charactaristic of wheel speed sensor failing
wire to the speed sensor fault and goes open circuit only with certain suspension movement
even an auto electrician/workshop with a decent scan tool could check all four wheel speed sensors on live data and store them and read back after a test drive... but min of 50 bux for "hook up" charge as stated before.... its a rip off but when the tool costs up to 20k you would want to charge it out too.
just took it for a drive this morning. Very weird thing. Car took a long time to start up .... like 30 secs of cranking. normally its first pop. and now its gone back to first pop start. Also the ABS lights gone away lol for now.
    574.7k
