Hey Guys!
So I bought my Legacy recently and I noticed that sometimes (more evident when spirited driving) there is a loud clunk / thump from the rear differential (I suppose) ... the car seems normal, and after lifting the car up I noticed some broken bushings on the rear diff, is that the cause? or should I look for something else? if so... will replacements fix the issue? also is this critical or something that could hurt more in the long run and finally .. where can I get replacements or OEM parts? which one is better...
Thanks!
Rear dif bushes are the villains in this case. I did mine about 6 months ago. Was $80sh for the pair from Subaru. They are quite hard to get in and out. Not tricky, just hard.
are they interchangeable with similar Subaru models? or are they specifically only for the legacy?
Well, I'm the Dominican Republic, and the authorized dealer here has no idea... so if you guys can find out.. I can at least order online!!
Thanks a lot mates, appreciate it!
Cheers! :)
    574.7k
