intake manifold?
anything will fit anywhere with either a grinder or ky lube.. but you will have to tell us what manifold on what car... a v8 manifold wont fit on v3 engine....but a v4 will fit on v1,2,3 etc...
i have a v4 intake all set up ready to bolt on for you if you want... also have factory sti v4 i/c for extra 100
you can have for 200. its just been painted and cost 120 to paint sooo..... and its got new split rails and injectors and throttle body and icv and alloy coolant headder tank...
oh i forgot to say... the intake manifold is a v4 but the fuel rails are v2... i had to modify them and the manifold to fit.. so it can now take either v4 or v2 rails.... good day
what fittings are welded on the rails and are the mounting points on them still factory? i might be keen on them for my v3 intake, what you after?
there just threaded in aye... theyre 1 piece brass fittings. theyre not cheep either.. its just nominal bore 3/8th fittings. no the nounting points arnt factory... theyre bent down to bolt up to the v4 manifold. 50 bux will own the rails with injectors.
ahk probly not what im after as they wont bolt straight up, cheers anyway :)
