ТТ on mono restyled adjustment
mitrich
Hello, everybody! Does anyone have an experience with monoturbo restyled(D) adjustment, legacy BE5. "Brains" 16 bit, mechanical flow control valve, AT. The problem is with transmission shift from 2 to 3. The basic firmware is taken from WRX, we have switched out AVCS in it. Check does not work. We used MAF HAK for adjustment since 16-bit "brains" do not see over 300 grams. You may have such an experience? Or probably some particular person from your forum may help?
Yes.
If you drive with a fully open throttle to boost off when you switch off 4EAT injector
1 to 2 no problem
2 to 3 problem, switches, but with a delay and twice ECU disables the injector, as the first time for some reason, he can not switch.
3 to 4 no problem.
Here is the log itself firmware. I think that is not the correct setting ECU
