Coolant leak
sti555
hey guys im just trying to identify which hose is leaking on my wrx.the leak is coming from the passangers side.underneath there are 2 elbow coolant hoses 14mm-16mm hose and 20cm long or so one sits on the other pretty much.they connect to the steel pipes that run up the front of the block..what whould i could these 2 pipes.
there the 2 hoses off the waterpump. they both feed up to the top of the engine .... one to your heater core/water for throttlebody and idle controll valve and the other one to the top tank on the manifold. there should also be another on the opposite side of the waterpump which goes to the oil cooler/warmer but some cars dont have them but turbo models should.
easiest way to replace them would be find some more from a wrecker.
if its not the 2 that are leaking it could be the thermostat housing which is next to the other 2 hoses (the big rad hose connects to it)
