P2011 Tumble Generator Valve DTC
kiwisurf
Hey all
Anyone had this code before?
P201 Tumble Generator Valve signal 2 Circuit Malfunction (open)
Car is a 03 BP Turbo.
Apparently alot of the Imprezas have them as well.
Searching the net shows that most people buy a delete kit or remove the flappers them self and match port the manifold.
What have people on here done and how do I keep the code clear?
Cheers.
Not in Auckland Subirex...in Hamilton.
Have had it on a code scanner. Code clears and then comes back. Turning the car off and on again will clear the code but it comes back after normal driving.
I think the WRX ones are a bit different....My car has the alloy manifolds between the plastic intake manifold and the heads. No sign of a stepper motor on either end where the butterfly shaft would be as per pictures I have seen of USA market models.
Person I spoke to at Wingers said there is one in the manifold somewhere?
Does anyone have a digital manual for this model??
i only have manuals for jap import and nz new. tried searching for that code in those manual but its not there.
if there is a TGV in yours than there should be a sensor (looks like a TPS sensor)
on each side of that aluminium manifold.
by the way that aluminium manifold is in all bp turbos but without that TGV.
can you post a photo of your inlet manifold?
I went and had a look at some cars a SubWrex in Hamilton.
There is a WRX in there with the TGV but none of the Legacys have it and mine looks nothing like the WRX that does have it.
Both ends of the aluminium manifold are just blanked off as per the better picture.
Could someone have changed the computer or something??
History of the car is I have only owned it approx 2 months and 1 of those it was in the panel shop while I was overseas...Been driving it for 3 weeks now with no CEL only for it to come on on the way home from Rotorua on sat.
