Using a bluetooth OBD Scan tool on a 2000 Legacy??
Hollow
I used one of the scan tools on my 02 rev d legacy. It can read and clear codes but couldn\'t read the sensors for active data or logging. Worked the same in my V7 STI and BP5 too but not sure about earlier models
I have 55 options I can select but don\'t have Knocking Correction, Atmosphere Pressure, Differential Pressure Sensor Voltage, Manifold Relative Pressure, either of the wastegates (understandable since my car is n/a), Fuel Pump Duty, either of the Relief Valve Solenoids or the AT Engine Torque Request.
