Adjustable Rear Swaybar links??
B4_685
Hi Guys,
Was working on brakes today and noticed my rear sway bar hasn\'t got much tension in it. Unit is adjustable (threaded and locking sway bar links) so I was going to tighten it up a bit to see how she handles. I noticed most of the Whiteline bars have \'holes\' in them to adjust the arm length for \'stiffer\' or \'lighter\' response from the Swaybar under cornering. Anyone experimented with this kind of link on a B4 before?
I understand if I add more tension, it will decrease roll tendancy or \'stiffen\' the rear end in corners. Anyone had any oversteer stories with too much tension?
rear swaybar:
bracing: (Notice the adjuster on the sway bar link)
Front "K" Brace:
Lower Control arms
After-Market Fujitsubo Exhaust
Wrapped Headers:
All car mods were done in Japan - anyone recognize any of the hardware from the (somewhat grainy) pics?
Thanks for the input :)
Dont bother it wont do anything, a sway bar works by keeping one side the same as the other. If both wheels are at the same droop there will never be much tension. by adjusting them youll only adjust where the sway bar sits
Thanks Stoffa - was just going to adjust to remove the play at full travel - short term fix til I can replace bushes.
