Removign Power Steering Rack
So failed a wof for having a leaking power steering rack among other things.
Has anyone removed and installed a power steering rack befoer and got any tips??
Iv found a few how tos on the net.
Have had on a hoist and sussed the orings are lekaing the top 2 so the hardest ones am going to do myself save some $$$
Just had to do this myself. The only hard part is getting to and undoing the lines at the bottom of the rack so you can drop it out. I removed my up-pipe to allow enough space so I could undo them - was pretty simple with that out of the way.
After that just undo the mount bolts (underneath), and disconnect the tie rods and it will drop down :)
yeap they look like a right pain to get out..
GOt told could drop axle out of way if i wanted but think il just get inthere give it a go and see how it goes lol..
The ones on the top need new o rings so needs to come out
Can be done in place
Need lots of patience and cut down spanners to do this job
Words of wisdom..... Make sure you start the threads by hand (finger tips) first
Have seen many racks ruined by cross threading rack fittings
Also make sure this is where it is leaking from first !!, It is common for top seal to fail, esp when turbo heatshield has been removed
PS good luck
 boostcut']
do you want me to bring some stubby spanners around and help you?
yeah bro stubby spanners hahah would be mean man...you free sometime on the weekend...text me cauase i dont got the net at home
PS good luck
Cheers man yeah it is thp seals have had on a hoist and had al ook with mechanic lol
