Brake fluid change quantity?
I do mine quite regularly (to keep the fluid fresh). I\'ve found 1 litre to be plenty if filling from dry, and usually have a bit left over.
This is on a GC8 (with 6 piston front and 2 piston rear calipers though - standard calipers I\'d guess you\'d need around 750ml if that???).
Yeah its pretty simple, and the whole system takes a lot less fluid than you would probably have thought.
Front bumper is off the shelf/trademe (Chargepeed style?), but I had to modify it to make it fit. Was pretty average quality, and I think possibly for a widebody as it wouldnt fit to my guards so did a bit of a cut and shut to make it work.
The few pics I have seen of it look sick Im a big fan.
