Output For Sensors
Bazza-NZ
Hey Guys,
Just putting back together my engine and there are a few sensor that are adjustable, however i forgot to mention to him to mark them down before he removed them
so i have a multimeter handy now so what do i need to test them and more importantly how?
the major two i can remember is the TPS and ICV and what values should i expect to see?
Cheers for any help in advance!
 kamineko said:
CEL code 31, EJ20G TPS Throttle Position Sensor (EJ20G only)
CEL code 42, Idle switch (EJ20G only)
in the multiple help stickies
Cheers Guys,
Yeah 1992 GT Legacy
Will check them out, i used the search bar but struggle to find what i was looking for... i remembered seeing it somewhere tho.
TPS is 4.5V closed. Set the ISC to about the middle, or see if you can see the old lock-down screw witness marks.
dont you mean 0.45??? the actual spec is 0.50v at closed throttle
