AFM upgrade
94bg5
Hey there I have a 94 bg5 ej20h im running a slightly bigger fuelpump and 550cc yellow sti injectors with a semi parallel turbo setup, forged pistons and rods and a little extra boost, but with the standard ecu. My k&n air filter leaked oil onto my afm, so i\'ve switched to an apexi dry filter and i was going to replace the afm.
My question is when getting a new afm are there any upgrade options that will play nice with the standard ecu?
Im not worried if i hav to do a bit of wiring or repinning the plug, just dont want to replace the ecu or loom til i do an ST conversion.
Thanks
Changing your fuel pump wont effect anything. Any change in injectors and afm they both need to match your ecu tune. A little extra boosty and slight comp change you will probably get away with. Btw the yellow side feeds are 440cc and phase 2 seem to make a little more power than phase 1 440cc.
AFM, injectors, turbos etc are things you need to tune for if you change or they will never play nice.
Thanks. Fuel pump made a huge difference considering the 1 it replaced didnt pump fuel. Having said all that are there any tt ecu\'s i could that would make a difference? I\'m pretty sure its an R6 in it now, blue sticker anyway. Im guessing not due to compression differences. Theres no problem with how the cars running or anything, its smooth, cheap on gas, beats b4\'s and keeps up with/sometimes passes sti wrxs, so im not really after more performance or anything, more a learning thing for myself, see what parts i can frankenstein together to get what results. One thing i would like to fix is the VoD that i\'ve nearly got gone, only drops 4-5psi when it opens up i/c valve now. I know really the only way is ST conversion but thats boring.
 94bg5 said:
Thanks. Fuel pump made a huge difference considering the 1 it replaced didnt pump fuel. Having said all that are there any tt ecu\'s i could that would make a difference? I\'m pretty sure its an R6 in it now, blue sticker anyway. Im guessing not due to compression differences. Theres no problem with how the cars running or anything, its smooth, cheap on gas, beats b4\'s and keeps up with/sometimes passes sti wrxs, so im not really after more performance or anything, more a learning thing for myself, see what parts i can frankenstein together to get what results. One thing i would like to fix is the VoD that i\'ve nearly got gone, only drops 4-5psi when it opens up i/c valve now. I know really the only way is ST conversion but thats by far the smartest thing to do.
Fixed
Re; AFM - nothing is an "upgrade" but what would be would be removing the 550s and putting the 440s back in
They run pig rich stock, it will now be running even more so and likely making less power than before, the factory ecu keeps them still at like 10:1 even with mucho psi being thrown into the mix and adding 25% on top won\'t be helping
Short answer just get another stock one haha
