bent clutch fork causing bad shudder?
2000 legacy b4
http://pdmusa1.com/
http://allwheeldriveauto.com/subaru-parts-4/
That\'s just a couple of random google links I found now, but read something similar when finding a how-to DIY a clutch replacement the other week
It\'s something to do with the shaft the release bearing slots over getting some wear over time - and the worse it chatters, the worse it becomes?
short version: not the clutch, flywheel, or bearing may actually be the cause but the sleeve/ surface the bearing rides on?
THAT SAID my old clutch juddered like you wouldn\'t believe, new one smooth as silk, new one is heavier - go figure - plenty of people have found identical cars / setups behave different, one can shudder but the next is fine
Regarding the clutch fork - I\'m not sure how you\'d bend it as such? Would have to do something pretty animal to bend that I guess
