Speed sensor signal and link Ecu
Is there a way of running the speed signal into the Ecu instead of the dash (link g3) as I need to do this for my iq3 if I wish to use it without oem dash.
I don\'t even know how the speed sensor/signal works on a gc8 v6 anyone care to educate me?
 gotasuby said:
yes you can. Signal should be split between ecu and dash and you can just un plug dash and there should be a speed sesor wire down at ecu already.
Awesome, now I need to work out if running only the iq3 dash is legal or not? Hopefully with speed output and hopefully odometer output it will be.
