GTB + 6000rpm = Check engine.
Hay
Just took my GTB for abit of a cobweb blowing out session. As i was in 3rd Gear , about 6000rpm the car stopped revving , and the check engine light came on......And would only drive along nice and steady. But as soon as you got over 6psi , it would stop revving etc. Turn the key off, And start it again , no check engine. but when you go for a boost same thing happens. Only on Secondary Turbo thou. Any help ? Car just has a Pod , FMIC and a Muffler.
Jason
 DRFVDR said:
it has gone into limp home mode
why it has could be many things including overboost,knocksensor
do a ECU reset and see how it goes
Just checked the codes.
13 - Cam angle Sensor .... Help ?!?!?!
23 - AFM ........................ Help ?!?!?
66 - Overboost................ Help ?!!!!!
Im not sure about the Cam angle and AFM , ill reset the ECU and see whats wrong with it. Thing is its never down this before ,only today for the first time
Any help in the mean time ?
Chur Chur
  • 3 weeks later...
 Ichi Ban said:
reset codes and see what comes back after another drive
Just put a new Walbro 255 in , after the standard one decided to die. Took it for a thrash , and yeah #66. So " Overboost" Strange thou, the boost is at 5psi on primary , so pretty sure its poked , but pretty positive the secondary turbo didnt even make it past 11 before it popped the code.. Any help!?
5psi is too low for primary boost ( that lower than w/gate pressure)
I'd be looking at primary BOV, and also secondary BOV
