Hello everyone again,
Ok my workmates got a yr 2000 Lancaster with the 3L 6 cylinder engine, on cold starts it takes a while for it to fire up but when it does itl run on a couple less cylinders than normal, he said when the engines warm its good as gold and it wont missfire under load or anything, I told him it might be plugs perhaps but does anyone else have any clues as to where he should start looking?
Cheers!!
ask if the fans are going when its cold? (with the ac switched off and before he starts cranking) , sounds like a possible coolant temp sensor fault
Is this only for the first 5-10 seconds of running and clears up if you rev it up a bit?
Yeah apparently so, he said when you start driving its good as gold
Mine does it maybe once a week. Ive never bothered worrying about it as it only happens for the first 10 seconds of running.
we had a service bulletin come around work for that problem as my workmates mrs has one also... it was to do with temp sender that was out of range or not reading properly. we put a resistor in the wiring to bump up the resistance of the sender and in essence has got the motor to run slightly richer before the o2 sensors warm up and correct the fueling.
his is now running perfectly and has been for about 2 months now thru winter
but keltik ^^^^ runs a link g4 im told and he shouldnt have the problem as the tuner would have set the cold start fuel maps accordingly.
Nope butchered stock ecu here
oh really??? well that may explain it. i thort i had read somewhere you had a g4 or wer sayin that you could only run m8000 motec or g4 link? ohwell. maybe il ask him exactly what he did and what size resistor... i remember him getting it from dick smith
    574.7k
