help with surplus wiring & alarm
sooby
Hi guys,
Today I've been trying to remove the TV antenna & wiring that came with my car, and while doing that I came across a massive amount of surplus wire that connects to nothing (left over from a GPS / TV tuner / god knows what else) and I'm a little concerned that if I remove this redundant wiring that it may screw with my alarm & immobilizer.
Heres a pic:
and here is a pic of where it joins the cars ECU (small red plug at centre left) :
Rational part of me says that seeing as how none of that wiring was connected to anything when the alarm was installed - it shouldn't change things if the wiring is removed. Just wanna check first before I go all snip happy tho!
Any alarm / electronics experts out there able to tell me if I'm likely to run into trouble if I remove all the cables?
cheers :)
Guest loren
don't touch it unless you know what you are doing and the entire loom is out of the car
before hand. it's kind of pointless just chopping the wires off where they enter the loom,
and opening up the loom is a pretty big and complex task.
cheers guys for your comments.
all the excess wiring is just sitting there & is only connected to the original wiring loom at the ECU by that one lime green wire & red junction box.
I guess I'll label which wires I cut & hope if sh!t happens I can simply re-connect what I cut.
thanks fullas,
GPS makes sense, funny thing was, I think there was one yellow wire going from the surplus wiring the length of the car to the tail-light / brake light, wonder what that was for?
Guest lan_killa
as long as your certain its not connected to anything then remove at will, but would recommend you remove 1 wire at a time then check everything still works before removing another, unless certain its got no other connections.
option 2, tidy it up... small cable ties and black tape = win
 lan_killa']
sounds like the best plan, cheers!
mate, there is at least a metre or two of wiring there - I'd rather loose it completely than have to hide it under the carpets.
[quote name='boostin said:
If you're in Auckland, bring it to me. I'll rip it all out for you.
thanks for the offer - but Im in taupo
Guest boostcut
i see your in taupo... go to wings and wheels hyundai, ask for deon. tell him adam sent you. he will sort you out a sweet price.. i.e bourbons or something.
 boostin said:
Sweet. You'll get an extra 200 metres per tank now. ;D
ha, ha - heres hoping!
plus I've listed it all on tard me, so may even get some sucker to pay me to take it away (instead of me paying to dump it!)
