SRS Airbag Module/Clockspring Replacement - BE5 Legacy
LegacyB4
I need to replace the SRS module and clockspring due to the one in my car has fried somehow. Does anyone know whats involved in replacing this? Is this a straight swap, plug n play, or does the module need to be reprogrammed to suit the car?
Thanks
Thanks
You will need a clock spring from a vehicle that is the same as yours, as the clock springs changed fairly regular, there can be different ones even from the same model depending on spec of vehicle
