Firstly, thank you guys for all the information on this site, I've finally found out what the problem with my car is :D
The Engine Coolant Temperature Sensor is throwing a fault which is simple enough, I'll CRC the connectors and give it a good clean but is that fails I'll need to replace the sensor (might just do that anyway for the sake of being thorough). However, I'm a pom and I have no idea where to buy parts from over here! Is there a company that sells most things or does nay one know of a retailer in Wellington I could order one through? any help would be much appreciated!
Or order direct new replacements from your Subaru dealer. Always worth checking the price there first
 1994legacyrs said:
Got mine through repco but it cost an arm and a leg..
If you need to know how to replace it on an ej20 I can help.
Good luck!
Mind if I ask how much?
As for the know how, I found this site:
http://www.lovehorsepower.com/SubaruDocs/CoolantTempSensor.html
which seems to pretty much cover it, if you have the time to take a peek and tell me if I'm along the right lines that'd be great :)
 1994legacyrs said:
$70 if I recall,
If yours is an ej20, the coolant sensor is located under the alternator. It is easy to take off, only takes around 15 minutes to replace.
$70 isn't too bad, I was thinking you were talking in the 100's when you said árm and a leg'!
I think mine is the one on the site I linked to, I had a quick look but it was getting dark and I was supposed to be working :S
Cheers Keltik, oddly enough, that's the last thing I would have thought of! Have sent them an email though :D
    574.7k
