Hi peeps,
Does anyone know what the standard tyre size is for the factory 18 inch alloy wheels??
Is 225/40/18 correct?
Where does one get good deals on 18 in tyres??? they're sooo expensive!!!
Cheers,
Willis
215/45R18 is the correct size. Factory fitted with Bridgestone Potenza RE050A's.
Mine has 225/45/18 which i know is incorrect. 215/45/18 is the correct size. Speedo is out slightly.
I need two new rear tyres soon, fronts are almost brand new. After both sets are worn down I may look at getting 4 new 215's. But like you said they are really expensive.
I've currently got bridgeston Potenza RE030's, another factory subaru tyre.
    574.7k
